Replaced left/front ABS sensor, fault 00283 (G47), and ....
it won't go away. I searched and it all points to a grounded or open circuit between the sensor and the ABS module. The sensor's plug to the harness looked just fine. Tomorrow I'll check the plug to the module. Hope I find something.
Does anybody know of a common ABS wiring problem with our cars? TIA.
You still getting fault codes then? There's always blasting the ABS rings with air to clean out any crap in there? Just a thought. Or maybe the sesnors to far in / not far in enough (fnar fnar!)
somebody did find a defect; saving me a lot of troubleshooting. The code keeps coming up after clearing.
You can see it rotate through the whole for the sensor. Possibilty of there being damage?
Like yourself I'm just getting into the ABS system, but from what I've heard it's extremely unlikely that there would be a loom fault. No harm to check though.
Another option may be to swap the two front sensors around?
LordKarnage17
10-17-2017 12:09 PM
Pizzicato
Performance and Tuning
11-13-2003 08:45 AM
