Replacing fuel pump: Can I use standard hose clamps or have to use crimp clamps?...
I think my lean condition may be due to bad fuel pump. I can audibly hear my fuel pump in car and out of car. Can I use just plain old hose clamps when hooking hoses to fuel pump or do I need to use those crimp clamps that's on it right now? Any advice when replacing? And can I change it with a full tank (just filled yesterday)?
The cheap ones do not seal all that well in any size, in the smaller dia even worse.
Just be sure to get high quality ones that are smooth all the way around inside and pull/tighten evenly. It's hard to describe but if you look at some different ones side by side you'll see what I mean. There are certainly differing qualities of hose clamps. Also make sure they are stainless steel, and ALL stainless, not stainless with a mild steel screw/bolt etc.
AudiWorld Uber User
it's not a direct fit. You have to trim a little off the pump housing and crimp a couple of wires to accomodate it. Run your tank as low as possible unless you like working submerged in gasoline. Seriously, you want the low fuel light on in the dash before you do this job.
quattro90S6
Audi Original "S" Cars
11-25-2008 04:44 PM
Mica
07-31-2008 02:56 PM
VR_Life
02-18-2006 11:50 AM
