Replacing valve cover gasket, timing belt
How much should it cost me to have a valve cover gasket replaced? What about the timing belt (I'm coming up to the point where I need it)? The dealer was telling me somewhere between 600 and 700 dollars, I believe. Does that seem high?
6 to 7 hundred is not bad for timing belt, on a 2.8, Assuming that the waterpump, rollers, thermostat etc are also being changed.
valve cover gasket is not a hard job at all.
further, if you follow the full procedure, where you loosen the cam srpockets, you will need the tool for when you re-torque the cam sprocket bolt.
way, the cams do not move - not like on stock 4 cylinder twin cam cars (separate exhaust, intake sprocket) were they would twist towards each other .
So, before I took the homemade tool out, I just used liquid paper to draw timing marks on the old belt, a belt cover bolted on the engine, and all the sprockets.
And no they don't move at all, but if they did, it can be easily rotated by hand.
I don't loosen the cam sprockets when replacing the belt. I've read the bentley about that, but when I took a look, I figured I didn't need too, and I was right.
I have pictures but they are at home though
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
the cam sprockets. What the tool allows you to do is loosen the cam sprockets, put the belt on, and torque the bolts, while keeping the cams in perfect alignment. Of course you have to remove it to change the pump, and of course the cams don't move by themselves. But, it when you put the belt back on where you want the tool. Is it ok to do it without? Sure, but I didnt want to chance it.
