Replacing valve cover gasket, timing belt
#11
once the belt is removed from the tensioner, it can be slowly removed from the rest of the gears, starting with the passenger side sprocket, then under the waterpump, then driver's side sprocket then driving crank shaft sprocket.
The liquid paper marks provide a reference point, and if the sprocket rotates slightly, it will be off a tooth or so anyway, it's pretty easy to tell. So far no problems.
I guess I like to cut down on time when I can. I don't think the Audi is unique is the hundreds of belts I've done. The only thing they don't provide is timing alignment marks other than using the special tool - or if I open the valve covers as there are some in there.
#12
on the end of the cams, which is why the end of the cam has that diamond thing on the ends. You loosen the cams, so they can turn and line up with the new belt exactly, if you dont, there is the possiblity that you could be off half a tooth or more.
Again, not saying your way is wrong, or bad.
#15
that means it's a built in cam sprocket adjustment for fine tuning and performance - no need to buy those after market adjustable sprockets
Hmmm future mod.
I'll need to fabricate a reference plate for use on a dyno tuning since on the 12V, those two cam bolts are relatively easy to get to.
#17
year, as I plan to swap my 7 year old (gulp) belt before I do any track events early next year.
gggdds
03-09-2010 09:08 AM
4taz
01-09-2008 05:22 PM
audiringpwr
07-12-2004 06:31 AM
