REPOST: Stg4 SB OFE clutch is in... a quick pre-break in review...
<center><img src="http://www.dxdracingclutches.com/images/ofe_street.gif"></center><p>
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2685029.phtml">https://forums.audiworld.com/a4/msgs/2685029.phtml</a</li></ul>
I believe I have a stage 3 HD. I didn't want a heavy pedal. I am near the limits of the clutch with my stage 3 but it does fine.
a k04 Giac hammer-file and most would be anything with less than 450lbs torque
I'm also confident the clutch will run whatever I throw at it. The last thing I want is to have to re-do it b/c it's not strong enough!
Clutch engagement was lower than stock and pedal was a little stiffer. It takes practice for a smooth clutch engagement. With a LW Flywheel it needs alittle more gas to be smooth. I did a 1k mile break in just to be sure, but I have a GT28RS.
Unorthodox Racing flywheel.
It is a slightly used setup from n0yxl<ul><li><a href="https://forums.audiworld.com/a4/msgs/2684818.phtml">https://forums.audiworld.com/a4/msgs/2684818.phtml</a</li></ul>
how aggressive should I be driving the car in break in? I really have not started but, I take it just slow starts in 1st gear.
