reprogram ECU from automatic trans to manual trans
Old 07-03-2003, 06:04 PM
New Member
hohol's Avatar
Default reprogram ECU from automatic trans to manual trans
Hi!
I have AUDI A4 Q 1.8t 5 speed manual
I need to reprogram ECU from automatic trans to manual trans quattro
I have VAG-COM, can u help me
thanks
Old 07-03-2003, 06:07 PM
coocoomike's Avatar
well, for a 2001, the codes are 16251 for auto and 16201 for man...iirc, pretty sure.
Old 07-03-2003, 06:42 PM
New Member
hohol's Avatar
Default Re: reprogram ECU from automatic trans to manual trans
i've got it
manual:
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
auto:
Component: 1.8L R4/5VT MOTR AT D07
Coding: 06051 (GIAC Chip)
VAG-COM recode to 06201
Old 07-03-2003, 08:57 PM
Junior Member
Quattroleap's Avatar
Default 1st digit is country code, 2nd digit is emissions type, 3rd is drivetrains option, 4th is
transmission type, 5th is vehicle type. So if yours start with a 1 it's not usa market vehicle?
Old 07-03-2003, 10:36 PM
coocoomike's Avatar
are you sure? mine has always been coded this way...
Old 07-03-2003, 11:19 PM
New Member
hohol's Avatar
Default Re: are you sure? mine has always been coded this way...
yep, it work
VAG-COM
[Select]
[01 - Engine]
[Recode - 07]
Enter the code
[Do It!]
Write down the original coding for future reference.
Old 07-03-2003, 11:25 PM
coocoomike's Avatar
16251 and 16201 are original codings.
Old 07-04-2003, 10:04 PM
Junior Member
Default Here's a cut and paste from bentley manual.....
<center><img src="http://pictureposter.audiworld.com/49529/ecm_coding.jpg"></center><p>
Old 07-04-2003, 10:08 PM
Junior Member
Default Bentley example
<center><img src="http://pictureposter.audiworld.com/49529/code_example.jpg"></center><p>
Old 07-04-2003, 10:32 PM
coocoomike's Avatar
well, a lot, and i mean a lot of cars in the US have been originall coded 16xxx
Quick Reply: reprogram ECU from automatic trans to manual trans
