Reprogram Remote
Reprogram Remote
Ok, so I am now trying to reprogam the damn thing. I turn 1 key 1 click, stick 2nd key in the door, lock the door manually, hit the unlock button and then lock the doors manually and then unlock them manually again. Then, when I pull the key out, It will unlock the driver door for me once, thats it. The lights will flash if I hit any buttons within 5 second and then after 5 seconds neither the remote nor the lights do anything. Whats the deal?
Keeper of the Cash
Key/Remote Programming...
Insert key 1 into the ignition and switch to ON. Take key 2, instert into driver's side lock tumbler and lock car. Press unlock 5 times at 1 second intervals to erase all remote memory positons. Turn key 2 and unlock car, then turn off the car and remove key 1 from the igniton. Reinsert key 1 into ignition, switch back on, and lock car again with key 2. Now press unlock once on remote one, twice on remote two, etc. You can program up to four remotes into memory with this method. Now, unlock and lock the car again with key 2. Press unlock with any of the remotes, and the car should unlock itself. Turn the car off, remove key 1, and test all remotes. That should do the trick.
yk7209
02-16-2016 12:54 PM
nemesisa6
02-03-2008 02:28 PM
MikeA6
11-07-2002 05:44 PM
