reset check engine light?
I've looked and can't seem to find the right post on this. Is it possible to reset the check engine light on a '98 A4 30v w/o a VAG tool?
Write the codes down before you clear them, re-post here with the codes.
Don't just replace everything that the parts store suggests, some problems tend to throw multiple codes.
Originally Posted by AudiForum.ca
A4 1995-1997
Requires diagnostic tool.
A4 1998-1999
Press and hold button on right side of instrument panel. Turn ignition to the "ON" position. "OIL" or "SERVICE OIL" will appear in display. Release button. Pull out button on left side of instrument panel until "---" or "SERVICE ---" appears in display. Turn ignition off.
A4 2000-2001
With ignition off, press and hold button on right side of instrument panel. Turn ignition to the "ON" position. Release button. "SERVICE!" or "SERVICE IN xxxx MI" will appear in display. Turn button on left side of instrument panel to the left until display clears. Turn ignition off.
A4 2002-2006
With ignition off, press and hold middle button on right side of instrument panel. Turn ignition to the "ON" position. Release button. "SERVICE!" or "SERVICE IN xxxx MI" will appear in display. Press right hand button on right side of instrument panel until display clears. Turn ignition off.
A6 1995-1997
A6 1997-1999
Press and hold button on right side of instrument panel. Turn ignition to the "ON" position. "SERVICE OEL" or "SERVICE OIL" will appear in display. Release button. Pull out button on left side of instrument panel until "---" or "SERVICE ---" appears in display. Turn ignition off.
A6 2000-2004
With ignition off, press and hold button on right side of instrument panel. Turn ignition to the "ON" position. Release button. "SERVICE!" or "SERVICE IN xxxx MI" will appear in display. Press button on left side of instrument panel to the left until display clears. Turn ignition off.
A6 2005-2006
A8 1996-2006
Requires diagnostic tool. Allroad 2000-2004 With ignition off, press and hold button on right side of instrument panel. Turn ignition to the "ON" position. Release button. "SERVICE!" or "SERVICE IN xxxx MI" will appear in display. Press button on left side of instrument panel to the left until display clears. Turn ignition off.
Cabriolet 2003-2006
S4 1995-1997
S4 1998-1999
S4 2000-2002
S4 2004-2006
S6 1995
S6 2002-2003
S8 2001-2006
TT 2000-2006
