Reset OBC after replacing Mass Air Flow Sensor
Check engine light came on. I went to Pep Boys and computer came up with bad Mass Air Flow Sensor. They wanted 533 + labor and Diag to replace it. I found one at a junk yard for 50 bucks with garentee to work. Well I installed it and Check engine light is still on. Is there a way to reset the computer without going back to Pep Boys and them charging me 90.00 + dollars to hook it up to the computer?
Thanks
Chris
Thanks
Chris
Re: Go to a friendly AutoZone, tell them you replaced the part and want to get codes cleared.
There are no Auto Zones in Staten Island, NY. at least that I know of. Is there a no other way of doing this without buying a Vag-Com / Pep Boys etc...
ie: disconnect battery for 24 hrs or jump two pins on the obc etc...
see if somebody on this list that lives near you will help
<ul><li><a href="http://www.steve-hall.com/cgi-bin/VAG-Locator.pl">http://www.steve-hall.com/cgi-bin/VAG-Locator.pl</a</li></ul>
