Reverse lights aren't working. Failed inspection. $340 to fix.
I was quoted $230 for the switch and $100 for labor. What are my options here? I haven't been able to find much info on this. Could it be a fuse? Is there a cheaper fix for this? $230 seems a bit high for a switch. One of my brake lights are out as well, if that matters.
Thanks!
Thanks!
try here: AudiDIY.com Audi B5 A4 Do It Yourself Articles
also here: https://www.audiworld.com/tech-articles/
Quick search, I can't guarantee this is the right one: https://www.europaparts.com/reverse-...12919823f.html
My recommendation is a couple/few of things:
1) If the shop gave you a printed receipt, check on there and see if there is a part #...
2) Go on a site like ectuning.com or my favorite: fcpeuro.com, enter your cars information, then give the part a search.
3) If you feel comfortable with it (based on what I've read, read for yourself please) jack your car up, remove the driver side wheel, find that switch - remove it and check to see if there is a part # on it proper. If there is a part number on the switch you remove, you will know that it's the one you need.
The difference between the ones you find online are likely oem / aftermarket. OEM are generally more expensive and more reliable, the one the dealer will likely provide... but you can get away with aftermarket parts depending on the part. I've never dealt with a reverse light on my own car personally, but I do have several aftermarket other things on it. Mainly because I'm a broke college student; If I had the $ I'd probably go for OEM on most things... but just like name brand clothes, some things are just overpriced for the brand. As long as you do a bit of research, you'll be able to make an informed decision.
Word.
Word.
