Rough idle and flashin CEL......
Old 05-30-2004, 08:47 AM
Quattromatt's Avatar
Default Rough idle and flashin CEL......
I think It may be a coilpack..... Any other ideas? Also If it is a coilpack should I replace them all and be safe or just 1. I vaged it and 2 codes came up...they were random/multiple misfires....and cylinder 1 misfire.
Any advice.....?
TIA
Old 05-30-2004, 08:57 AM
nightkrawler's Avatar
Default if you think its a coil pack , isolate the one in question, vag it
and get the code, example, say random misfire cyl 1, clear the codes then switch the coil pack to a different cyl, if it jumps, say you switch it to cyl 4, and you get random misfire cyl 4, you know its a coil pack.
Old 05-30-2004, 09:00 AM
kenny (dremel)'s Avatar
Default coilpack or ignition output stage - clear codes, swap cyl 1 and cyl 2 coilpacks
start her up, step on the gas, then read the codes.
If there's a misfire on cyl 2, it's the cp.
Old 05-30-2004, 09:20 AM
Default from the front of the car......
which one is CP #1......I am sure I can find it in a search, But what are the order of the cylinders, CP's?
Thanks.
Old 05-30-2004, 09:32 AM
i believe it goes from the firewall foreward 1 2 3 4
Old 05-30-2004, 09:52 AM
New Member
Braineam's Avatar
Default ahhhh yea, smells like the ignition control unit/power output stage, call it whatever you want.
from the front of the car 1 2 3 4.
while the car is running, you can unplug the coilpack, and see if there is a change in idle. then unplug coilpack, swap, do the same again.
1999.5 = bad POS, i had the same problem couple of weeks ago. CPs usually fail on 2000+, on pre-2000 it's the POS/ICU/whatever
Old 05-30-2004, 03:42 PM
Zodiak's Avatar
how many miles does your car have?
Old 05-31-2004, 08:32 AM
Default I moved the CP's around......
still misfiring cylinder 1......What/where is the ICU/POS? How do I know if need to change that? Or should I just change it and hope it fixes the problem? Also anyone have an idea how much it costs? is it easy to get to? can I do it myself? Thanks.
Old 05-31-2004, 08:49 AM
Zodiak's Avatar
Default it sits right ontop of your air box
do a search if you need pictures. There are 2 parts, one made by Bosch and one made by some other company. The Bosch one is like 300 and the other is 150-200 They both work identically so get the cheaper one.
The install takes all of 2 seconds, the part sits right ontop of your airbox, just unclip the 2 harnesses, and unscrew the two screws .
Old 05-31-2004, 08:56 AM
Default I found it thanks.....but i searched and the part is $350....
do you know where I can get the chaeper one?
Quick Reply: Rough idle and flashin CEL......
