is Royal purple's Max Gear 75w90 fluid ok in my 97 A4Q auto tranny?
#13
(the BMW LT71141 spec is the same as Audi LT71141)
THOMAS R. SMITH
Technical Director, Valvoline Brand
June 7, 2004
To Whom It May Concern:
Valvoline has received several inquiries regarding the topic of MERCON V ATF and its use in various vehicles beyond those requiring DEXRON-III, MERCON, or MERCON V approved products. In response to these questions Valvoline has issued the following statements:
Valvoline supports the use of MERCON V ATF in a broad range of transmissions beyond those requiring DEXRON-III, MERCON, and MERCON V fluids including those where the following fluids are recommended:
o GM DEXRON II
o Allison C-4
o Chrysler ATF+3 or ATF+4 fluids
o Toyota (and Lexus) Type T, T-III or T-IV fluids
o Mitsubishi Diamond SP-II or SP-III fluids
o Hyundai
o Honda ATF-Z1 fluid (except in CVTs)
o BMW LT71141 or LA2634 fluids
o Nissan Matic-D, Matic-J, or Matic-K fluids
MaxLife ATF is recommended for the new 5 and 6 speed transmissions, except the Ford 5R110, Ford 6RXX, and the Mercedes Benz W7A700 (7G-TRONIC) which all require a low viscosity Automatic Transmission Fluid.
Valvoline has conducted in-house testing to support MERCON V ATF performance in these transmissions. However, it is important to note that these vehicle manufacturers have neither evaluated nor approved MERCON V ATF.
Valvoline stands behind all of its products, including MERCON V ATF. Use of MERCON V ATF in transmissions where recommended by Valvoline WILL NOT void the vehicle?sup>TMs warranty. In the unlikely event that any transmission was to be damaged as a result of the use of MERCON V ATF,
please contact Valvoline at 1-800-Team-VAL.
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=16;t=002116;p=0
Also:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=16;t=002683
THOMAS R. SMITH
June 7, 2004
o GM DEXRON II
o Allison C-4
o Hyundai
Also:
#16
which brings me back to the new Mobil 1 "Multi" vehicle. Hard to imagine, but the friction modifiers in "Multi-Vehicle" ATFs selectively match the proper coefficient of friction for the type of clutch material in the trans. So, Mobil 1 basestock is good, it HAS the Multi FMs....I'd use it. Not rated for Honda Z1, but I use it in my CRV, works great. Probally going to use it in MIL's 1995 A6. Likely way better then the older Audi ATF and I won't have to mess with it again. Valvoline...why bother?
transmission/differential fluid with Motul Gear 300 is this the best concensis for fluid replacement
lion of manervia
03-28-2008 08:39 AM
eigenvector
20
09-03-2006 08:35 PM
97A4_UT
07-06-2006 05:03 PM
deserTTcruiser
11
11-17-2004 06:40 AM
KaMaKaZieP -ALUMIN8-
08-12-2003 04:54 AM
