Is it safe to bypass the N249 on an '01.5 CH with APR stage 3? what's the other one in this pic?
Member
Search gives me this for the following components:
N80 - evap canister purge valve
N112 - 2ndary air solenoid valve
J299 - 2ndary air pump relay
N75 - wastegate bypass regulator vavle
N205 - valve 1 for cam adj
V144 - leak detection pump
N249 - recirculating valve solenoid
N30-N33 - 1-4 fuel injectors
The lower one in the pic on the "F" is the N249, correct? what's the other one? what does it do? How do I bypass the N249? I'd like to see if this will help fix my issue, if it's safe on an '01.
<img src="http://www.modifieda4.com/images/pcv-parts/DSC00945.sized.jpg">
Member
and, is this how to bypass? what did you use to plug the line on the "F"?
<center><img src="http://pictureposter.audiworld.com/87006/vaclayout.edited.jpg"></center><p>
beejohn
03-21-2006 03:29 PM
QuattroRocket
09-17-2005 03:34 PM
OPTIMUS PRlME
03-14-2004 01:21 PM
sirol2
09-04-2000 10:28 PM
