semi-urgent assistance PLEASE --> Dropping the front subframe to remove lower Control Arm Bolt
I need to drop the subframe to get the bolt out, but how do I do it? I've removed all the blots that I thought link the subframe to the frame but doesn't look like it's budging. Do I need to do both sides??
HELP!
HELP!
still firmly bolted up.. Be REALLY careful here, keep a jack stand under the subframe, to catch it.. It's not like it's going to just fall on you.. you actually have to pull it down to get the bolt out.
for when I do mine. Appears you have to unbolt the trianges(alu) as well as the subframe mounting bolt on both sides and support it. A+ post.
