Sending ECU to Unitronics and they say I need a 3.5fpr with the 415cc. While doing my swap of the
550cc's for the 415's, I noticed I have a 4 bar fpr. Will this work or does it have to be exactly 3.5. Not too sure about how all this works and couldnt find a good answer.
since they are larger then the 415cc injectors. If he was to go with the 4bar fpr he would need 380cc injectors so that the flow rate is the same as 415cc with 3.5 bar.
415cc at 3.5 bar = 42.68 lbs/hr or 448cc.
380cc at 4 bar = 41.78 lbs/hr or 439cc
They tuned the file for that specific injector/FPR combo. 3.5 is a weird one - you can either buy it from USRT:
http://www.usrallyteam.com/index.php?main_page=product_info&cPath=10_57&a mp;products_id=132
or get an adjustable regulator.
end up with more room to play with duty cylce wise with the Genesis 415 due to the efficieny of the spray pattern working with our intake valves. The 440cc have a pattern setup to work with VR's and you end up getting much more inefficient fueling control with them.
I was also running a 4bar PES/GIAC file with 415cc Genesis when I was running the 2860rs.
But that still pretty much means that 440cc with 4bar isn't going to work which was my point ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I mainly sell the 550cc and 630cc injectors more since thats what is called for on the REVO GTRS and GT30 tune.
cpayne
Audi Original "S" Cars
01-21-2007 07:01 AM
EdyJun
18
07-17-2006 08:08 AM
mmart6545
11-23-2003 07:32 AM
