To Shabbis, would you please post procedure if you successfully change your fog to HID jahn bulb?
Guest
Posts: n/a
Here's the post:
<I>Remove the grid besides the for assembly, both sides. Then, pull out the plastic triangle shaped cover on the fog light, they are held with 3 clips, easily removed. Unscrew three screws. Then, you have to kind of push the fog light assembly inwards, and then pull it out with a certain angle. The rubber piece on the assembly might be on the way, but just pull it out a little more force, it won't hurt anything. Then, twist off the round cover at the back of the fog assembly, unplug the connector, unclip the light bulb, and VoLAA, you can put in different bulb.
I don't know if there's other easier way. But this only takes me about 20 minutes including reassemble. Have fun. Submitted by Jack.</I>
<a href="mailto:chinchen0131@email.msn.com">Jack's email.</a>
mm
01-18-2002 08:36 AM
heelu
11-17-2000 05:29 PM
silver surfer
05-10-2000 09:03 PM
