shaved lower door moldings....
<center><img src="http://pictureposter.audiworld.com/50830/audia4_abt_sideskirts.jpg"></center><p>I removed the lower moldings on the car so those little nubs could be shaved, and then repainted. Well i now see that right under the door is the rubber end exposed from the door sills. Is this normal? What do other peoples cars look like with the moldings shaved off? I am having ABT side skirts installed and it would look cleaner with it removed, until i noticed the rubber exposed a tiny bit. ???
thanks, chris
thanks, chris
You have to remove the door sills first and foremost..
<center><img src="http://www.erichsueh.com/images/Angstrom%20rear.jpg"></center><p>The ABT skirts wrap over the door sills. Your aluminum trim (if you are 01) is gone.
can you please further explain...im a little slow...
i completely take off the sills which have the aluminum "s4" imprinted on them? mine is a 2000 and i have that, i didnt add it. so i just take this completely out, what protects the sill then, i see how the skirts are cut to go completely deeper in the sill than the stock ones which just have a little edge, but wont the sill plate still go over it? i dont completely undetand...
how? where? heheh no seriously though.mine have the rubber flap...
did you just get rid of the rubber part or what? i have s4 sills right now, and they have the rubber stuff on it, with a little s4 emblem on the middle...what to do, ?
if you want to shave the lower tabs you need to completely repaint your doors
you might as well shave off the middle molding as well. i plan on doing this whenever i win the lotto but for now trim guard does the job.
<img src="http://www.imagestation.com/picture/sraid54/p9b2c2b5a7c447529919aaaf62d464ddf/fc82850f.jpg">
my shop wouldn't paint the thing, so it's that black strip that you see.
here's europrojektz's car, shaved like a **** star.
<img src="http://www.europrojektz.com/gallery7/images/110-1025_IMG.jpg">
<img src="http://www.europrojektz.com/gallery7/images/110-1054_STA.jpg">
