Short Shifter Install.
How hard is a install? I was thinking about doing one but wondered if it was a task I could take on myself? I am moderately technically inclined.
Thanks!
Thanks!
It's not hard to do. I just takes patience, lots of it. a friend who has already done it, makes it
easier too. I suggest getting the C-clip tool to take out the "C" ring as it would almost be impossible without it, although, I'm sure it can be done. You'll also need (2) small 10mm wrenches. Also, it you're installing the UUC, I suggest doing Damon's zip-tie mod. It worked very well on mine to take out the "play".
It's easy if you have a set of ball end metric allen wrenches. It takes me less than 10 minutes to
install one. The ball end wrench is a HANDY tool for removing and installing the allen head cap screw that holds the end of the shifter into the shifter linkage. You can use a box end 10 mm wrench over the short end of the allen wrench for leverage.
step 9 out of 10 steps for installing the UUC short shifter. AND I HAD TO PUT IT ALL BACK TOGETHER..
TyWebb
12-23-2001 09:18 AM
2urbo
07-27-2001 02:41 PM
johsti1
12-12-2000 02:05 PM
