slight hesitation around 2.2-2.3k in 2nd gear.. any ideas?
basically what the title says.. Tiptronic in Auto mode, almost feels like the car is shifting into 3rd gear, but not quite. does not do it while in tiptronic mode. I would consider the transmission slipping but the engine actually hesitates for a second when this happens so it almost seems like a problem in the programming. also, this only happens when i am not giving the car much gas (auto will shift at 2-2.5k depending on gear with this amount of gas).. if i give the car a decent amount of gas this does not happen.
i am usually fairly good at diagnosing problems and happening only in one gear would normally dictate a transmission problem. however that would not explain why this does not happen while in tiptronic mode or how it only happens while giving a small amount of gas, or even why the engine actually hesitates when this happens.. any ideas?
William
07-04-2000 01:48 PM
britoki (Brian T)
06-21-1999 09:33 AM
