Slotted & Cross drilled rotors cause vibration??
I got Brembo factory replacement rotors with EBC green stuff brke pads on factory calipers. The problem I'm having is when I apply the brake semi-hard my steering wheel and car shakes.
Is that normal for slotted & cross drilled rotors?
Former Vendor
slotted and/or x-drill rotors do make a slight buzzing sound when you brake. There shouldn't be any vibration felt through the steering wheel however.
Double check that all your caliper, and carrier bolts are all tightened properly.
boonies
11-01-2008 12:41 PM
