Snub Mount?
For a 99.5 2.8 Is it possible to check for a bad snub mount without removing the front end? Can you see it clearly from under the front of the car with the lower splash shield removed?
...but Im not sure what you expect to see. Its a plain jane rubber mount that doesnt move much - so the only way I can see it going bad is by dry rot or something like that.
The snub is one of the best mods you can get, especially for the 2.8...I highly recommend it.
<center><img src="http://pictureposter.audiworld.com/29165/2.8.jpg"></center><p>To the best of my knowledge you should be able to see it with lower shroud removed. From the illustrations I've seen it looks as though you may be able to change it without removing the front clip. Good luck.
You won't be able to get to it from underneath. The APR website www.goapr.com has instructions on how to install it.
Here is the APR Snub Mount installed with the front end off:
<img src="http://mywebpages.comcast.net/mtdiblasi/TB5.jpg">
The Snub Mount is behind that rectangular plate underneath the aux fan.
<img src="http://mywebpages.comcast.net/mtdiblasi/TB6.jpg">
At least this is how it is on my car.
Mike<ul><li><a href="http://www.goapr.com">APR</a></li></ul>
You will still need to disassemble the front of the car per APR's instructions to install it. A timing belt change is the best time to do it. That's when I did it!
Mike
Mike
SteveAngry
04-02-2004 02:25 PM
supertran74
06-18-2003 05:39 AM
A4ORCE1
08-19-2002 04:43 PM
