So a B5 1.8t can hit over 160mph with a 2.8 trans...
bah, my window seals barely make it to 120
on a side note, the kickpanels are coming a long nicely. I was able to move 80% of the wires and have only lost maybe 20-30% of my dead pedal. These dynaudio speakers are rather large
did you leave the metal plate (under the carpet) in? or are you going just carpet?
I shoved most of the wires under the carpet, and then screwed the raised metal plate in over them it holds everything in rather securely and ensures that both the plastic deadpedal cover and the kick panel will fit in properly
Help a noob out, what do you mean your window seals don't "make it"
Do you mean you start feeling air coming into the cabin at high speeds? That seems odd...
thanks-
Andrew
thanks-
Andrew
