so i think my ecu is bad - i have bt - can i use a k03 ecu and try to start my car
you will blow it up. be sure not to tear the o-rings on the injectors. I assume you are controlling boost with the n75? Is this an eliminator?
--dillon
--dillon
I would recommend a MBC over the N75. Set the MBC to 7ish but dont f up :-) Keep the N75 plugged in to not pop a CEL.
--dillon
--dillon
if key is in on position, no check engine light. Just try putting the K03 ECU in the car, put key to on position (don't start car) and see if CEL is eliminated. If it is with the K03 ECU, and not with your BT ECU, then something on the ECU isn't correct.
DARKiGOD
02-11-2006 07:24 AM
TwisTTer
08-15-2005 04:50 PM
Morgan Hill Madman!!
08-15-2002 11:43 AM
Cerveza
07-19-2002 02:19 PM
