So I think my tranny is leaking! Does this sound right?
I'm leaking fluid pretty bad, I'm 99% sure the leak is from where the Driverside axle, where it bolts to the tranny.
The fluid it is leaking is an oil, color is very transperant, and slighty dirty, does this sound like auto tranny fluid?
Any idea how much labor would be involved to replace the mentioned seal?
Thanks
Thanks
Definatly looks easy from my audi service manual. Only thing I'm still not clear on is the fluid that is leaking. Is it tranny fluid, if so does that mean draining all the fluid? Remember I'm an auto.
Also, would a clicking sound from turning be related, or totally different problem?
Finally, safe to drive, or just wait to get fixed? It's leaking about .5-1 oz a day for the last 36 hours.
Thanks
Thanks
I doubt they can do it in an hour, dealer=nothing takes only one hour. It's probably a 2-2.5 hour job maybe? I'm not sure honestly but it's not that bad a job FWIW.
The seal is keeping fluid in your differential, it's not tranny fluid leaking out (at least it shouldn't be!) It should be gear oil.
Sound is probably not related unless you're REALLY low on fluid... sounds more like a bad CV joint or other issue. "Clicking" is a very very vague term and over the web is rather hard to diagnose!
Safe, yes... as long as not too much of the fluid is gone. Chances are it's fine. If you're worried pull the fill plug and check it/fill it up with synthetic gear.
Again, the leak is on the DS front axle where it bolts to the tranny. What color is each of the two fluids? Fluid being leaked is almost clear and slighty black.
Sorry for being redundant, I'm just not getting the answer, lol.
Thanks
Thanks
