So once again my amp decieds to cut out for the day...It is really starting to annoy me
Ground was fine as well as everything at the amp. Figure it was the fuse or fuse holder so unbolted and looked at that and it was fine. Turned the stereo on and it worked. This morning was about 20 minutes into my ride and it cuts out again. The amp is not in power protect mode.
how is the amp mounted? If its a powerful amp and is upside down, like on the underside of the rear deck, it radiates heat onto itself. Could overheat. Also, if you are driving too much of a load... say running a couple of subs in parallel (say 2 ohm load) when the amp is only rated down to a 4 ohm load, it will overheat. Thats just a start, it could be other things... hope this helps.
it is mounted upside down but I havent had a problem with it overheating in the summer and today was in the 60's. It was also on morning talk radio when it went out this morning.
pac1085
01-29-2007 05:21 PM
Ray Khan
19
09-07-2002 09:58 AM
