So what's the major difference(s) in the FWD & Quattro rear brake...
pad and rotor replacement procedures?
In the tech section it shows quattro replacement only so what am I looking for on my FWD rear?
________________________________________
which means, you're either going to:
1. Get new bearings, drive in the outer races, and pack them, and install the bearings.
2. Reuse your bearings that are already installed, not reccommended, because you are likkely to damage the outer races as you drive them out of the hub.
I have not measured but I am expecting to just smooth that down by slightly resurfacing.
So If I do not replace the rotors, then I should be able to follow the procedures of pad replacement for the quattro in the tech section?
A4noobster
06-18-2005 08:39 AM
Hokie - STI avant
04-22-2005 07:35 AM
Schlepcar
02-22-2002 12:28 PM
