Solving minor pinging problems in APR chipped 1.8T...(more, a bit long)
Guest
Posts: n/a
Here's the problem: with the APR 1 bar chip, I had been experiencing some minor pinging under full-throttle application below 2500 rpm (heard as 2 or 3 'clicks'). The problem seemed to occur mainly when the engine was HOT (oil temp around 220), and the outside temp was 90+ degrees F (I'm in San Antonio, TX).<p>After some experimentation, I found a solution! Add approx. 16oz. of Turbo 108 octane boost (made by North American Oil Co.) to a full tank of 93 octane fuel (I used Mobil premium). The result? ABSOLUTELY NO PINGING! The engine seems to run smoother and pull a bit harder too. I tried a couple other octane boost formulas, but none of them worked as well as Turbo 108 (and, no, I don't work for them or hold stock in their company).<p>Pep Boys sells a 32 oz. can of Turbo 108 for $6.99 (enough for 2 tankfulls).
Guest
Posts: n/a
YOu're problem is probably carbon deposits on you're pistons raising your compression ratio. I live in S Florida and have never had pinging with my chip. I run Techron ful aditive once every 3K miles and have never had detonation.<p>Try 2 bottles consecutively and see if that helps.
