Someone wanna take a look with me (codes inside)
4 Faults Found:
18021 - MIL Control Circuit: Open or Short to Plus
P1613 - 35-00 - -
17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2: Electrical Malfunction
P1198 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
Readiness: 0010 0001
I'm assuming this is because I have my #2 02 sensor not in the downpipe and off to the side (my wideband is in the DP right now). If I put my sensor back in, this should all go away...right?? I know the MIL has something to do with it and the ABS code is more than likely the controller under the hood (not getting replaced)
P1613 - 35-00 - -
P1198 - 35-00 - -
P0140 - 35-00 - -
P1606 - 35-00 - -
I've been running with the second O2 sensor out and I've only gotten 2 of those:
P1198 - 35-00 - -
P0140 - 35-00 - -
Never seen the other ones...
P1198 - 35-00 - -
P0140 - 35-00 - -
BTW, did the hard reset on the ECU tonight as suggested...no luck-->
if I rev the car slowly (in neutral) I can rev it up..if I mash it to the floor it stuters and cuts out. = my MAF is fried????
According to Bentley's it *might* be a coding issue
18021
MIL Call-up Circ.
Open/Short to B+
2 Dcy
- Check DTC memory for Transmission Control Module (TCM) and correct malfunctions
Repair Manual , 5 Spd. Automatic Transmission 01V On Board Diagnostic (OBD), Repair Group 01
- Check wiring between TCM and ECM
What's the soft code on your ECU??? ...lol
MIL Call-up Circ.
Open/Short to B+
2 Dcy
