Something fishy going on
I removed my stock bpv last night, and it does not have a vacuum hose attached to it whatsoever. I removed only 2 clamps, and there were only 2 openings on the bpv. everyone is telling me that there should have been a smaller vacuum hose attached as well, but this was not the case. I have a 20001.8TQM if this makes any difference. What's the deal? Did some years not have the vacuum hose?
<center><img src="http://www.users.qwest.net/~bkain/Diagram2_DV_Location_1.8T.jpg"></center><p>above turbo next to line shielded by silver snap on cover? If yes, then it's the recirc valve. Put it back
The DV is located on left side of engine (facing engine bay) under the radiator. You must remove the bottom plastic shroud to get to it.
would a tearing vacuum hose (i'm replacing it shortly) hooked to the bpv or whatever that tin can lo
RedBlackYellow
05-31-2007 06:17 PM
Mike2kS4
60
07-20-2004 11:33 AM
