Spark Plugs. . .easy to change?
I am considering doing more of my own maintenance. One that I am thinking about is to change my own spark plugs.
Is it pretty easy?
Do I have to change the wires as well?
Any tips or suggestions?
I have a '98 A4 2.8 30V.
Terry
Is it pretty easy?
Terry
Plugs are very easy to change. No wire replacement needed. To make things easier remove the coolant overflow tank (back right of motor). This takes only 3 screws and disconnect the sensor connector at the bottom. Also it makes it easier to take off the air intake box(front left of motor). Assuming your car is stock. There are 4 spring clips, 2 wire adapters and the hose clamp to remove. Then there is great access to the plugs. I recommend NGK iridium. Do not get Bosch +4 or +2...They are terrible. The plugs are pretty far down so you will need at least one extension for your socket.
yes I have used them and they fowl up quickly in the 30V motor. Not sure exactly why. But I put them in a a few weeks later the car started missing. Checked the plugs and they were charred.
That sounds like the wrong heat-range, such as a racing plug in a steet engine, or wrong gap, etc. I have basic Bosch duel-electrode plugs in my 12V 2.8, idles smooth and runs clean, and at about $2.50 each too. As to plug wires, you would need a new set if they are defective and causing a misfire.
1 Post
I have used the Bosch +4 and have not had the type of experience you describe. I have not had good experiences with the 'No-Good-Kind' on several occasions with Audi and other makes, so I was surprised to see what your experience was.
A little of both. All of them I pulled out had much more carbon deposits than normal. One of them was starting to bubble a little at the edge of the insulator.
As a counter point of view I've had both the Bosch +4's (~90k miles) and +2's (~10k miles) and have had no problem with either of them.
Get a spark plug socket with a rubber piece in it that holds the spark plug, but make sure it is not so grippy that the socket extension comes loose leaving the socket in the spark plug hole instead of releasing from the spark plug itself. Shouldn't be a problem, but worth at least a thought.
