spillages of coolant
My Audi A41.8m (97), I look at the water pump, and found there have a lot of spillages of coolant. My coolants are green in color. Is it because of seal or O ring of the pump? Can someone advise me?
You're using the wrong coolant. It should be pink/purple/orange depending on G12/G12+/G05
Keeper of the Cash
corroding the non-aluminum engine parts and depositing the rust elsewhere?
Seeing as I know have a metal water pump impelling, not plastic, Audi Junki recommend I switch to a highly silicated coolant, best known as G05.
Here's the housing half of my water pump, factory original:
<img src="http://i7.photobucket.com/albums/y293/FastA4Turbo/audi/IMG_1186.jpg">
<img src="http://i7.photobucket.com/albums/y293/FastA4Turbo/audi/IMG_1187.jpg">
Now, G12+ is supposed to be better and easier on metal parts than the G12 counterpart. Problem I have with that is how much it costs. I love being able to go anywhere, get green coolant, and toss it in. Plus, since the cost is so much lower, flushing it out will actually be easy enough to do and fluid easy to obtain.
