squeaking driving me nuts. I've definetly identified WHEN it happens. Help me figure out WHAT it is
High pitched squakeing sound from the front of the car
ONLY present when driving straight.
As soon as steeering wheel is turned slightly (45deg.?) left or right , the sound dissapears completely.
Speed bumps do not affect it.
Seems somewhat speed sensitive
Based on this im thinking it is not control arms (no affect from speed bumps)
Does it seem like a bad front wheel bearing(s) , would they only make the sound when steering wheel is straight and dissapear when turning?
Help.
Help.
Squeal much different than intermittent squeak. It's not your suspension if it's a constant squeal. If it goes away when you turn, maybe steering related? Then I'd say brakes. Then wheel bearing. Maybe a belt.
the definites are
sound dissapears when applying brakes or when turrning
sound not affected my speedbumps
all this only seems to eliminate it being the control arms
might be the brakes , power steering , wheel bearnings.
im going to have to start taking stuff apart now.
gettin my wheel bearing done soon so i will let you kno if that helped at all. josh
<center><img src="http://pictureposter.audiworld.com/35702/badpads.jpg"></center><p>These are my pads when I removed them @ 32K miles or so. They also squeaked in a similar way as you describe. (That's two pads... in four pieces!) ;-(
OneThirtyEight
12-02-2006 05:47 AM
kaiser_chef_beets
09-01-2006 08:30 PM
Stratocaster1422
06-30-2003 06:33 AM
Big Nodge
06-18-2002 06:52 PM
