squeaky rear suspension????
my car has squeaky noise from rear side. It makes squueaky noise when I go over bump. I noticed this last friday, probably after I made fast turn
What would be making those sound? is it control arm going bad? or is it just my rear side shock going bad? I have stock non-sports suspension with neuspeed 19mm swaybar installed 1 month ago. TIA
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
replace anything if that what you mean. You only want to lube the bar where it passes thru the bushings and the insides of the two urethane bushings .. the rest of the bar should be dry.
the clamps and lube them with a good silicone paste grease. If not then you'll at least know it is comong from elsewhere.
Pat
01-28-2003 03:21 PM
owdeeS4
9
04-19-2002 10:46 AM
