Squeeking noise when turning steering wheel to the left.............
<center><img src="http://pictureposter.audiworld.com/39094/mya4.jpg"></center><p>
Only happens when car is stopped. Anyone have an idea what it could be?
While your under there listening. You can actually touch any of the arms under there and feel the sqeal. From there you have to locate the bushing/joint that sqeaks and lube it up.
That it is a joint down there, use a grease that has the highest temp rating you can find. Pop off the ring around the boot and lift it up or down, grease it up and seal it up again. If you use the right grease, youll never have to do it again. The factory grease has been tested to dissipate.
Might want to take a look in your wheel well for a visual inspection- If it's a tie-rod it might have physical damage that will be visible. Worth taking 5 minutes to peek in there just to see...
Randy
Randy
