Staggered rims on a Quattro
What kind of problems can happen if I go with a staggered setup on my quattro? I'm trying to fit 18x8.5/32 mm in the front and 18x9.5/35 mm in the rear. Both have a 5x112 bolt pattern. I was told using a 10mm spacer in the rear would help with any rubbing I might have. Tires I have no idea.. 225/40? Does this sound alright?
without them streched. If you look at cars with 9.5 on the rear the wheels stick out a bit from the fenders. If you strech the tires it doesn't look bad. If you don't then itt is gonna look horrible.
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2176814.phtml">https://forums.audiworld.com/a4/msgs/2176814.phtml</a</li></ul>
