Starting problem..
Old 06-17-2002, 04:40 PM
New Member
swong_88's Avatar
Default Starting problem..
Hi,
I have a starting problem with my Audi A4 2.8 (1998). If I start the car in the morning, it starts fine. But if I drive around and then turn off the car, then try to start the car again after 10-20 minutes, it will not start. It will crank and continue to crank without starting. I have found that if I start hitting the gas while cranking, it helps the car start sometimes. If I let it sit for about an hour, then the car will once again start just fine. Does anyone have a clue as to what this could be and how to fix it?? I have heard someone say that it might be vapor lock. I have also heard that the temperature sensor might be broken. Does the A4 engine start differently for different temperatures?? Any help would be greatly appreciated. Thanks..
Sam
prxsteez
A4 (B8 Platform) Discussion
05-12-2017 06:46 PM
murof
11-21-2008 06:17 AM
Gizmo99
12
05-16-2006 06:27 PM
88audi90_Q
12-12-2003 03:37 AM
KLALE
09-25-2001 09:50 AM
Quick Reply: Starting problem..
