Starting problem
1998 Audi A4 2.8L
I have problem with the car starting when engine is warm, absolutely no problem from cold start. If anyone has experienced a similar problem and has a potential diagnosis I would appreciate the help.
Would start cold and fast idle and other circuits would keep car running after warm up car would almost stall at lights. Hot start car wouldn't stay running unless foot was on pedal and stumbled ,stalled intermittently . Cleaned throttle body with spray cleaner and cured the illness.
kind of starting problem you have. As Nate mentioned, more detail is needed.
Does it crank at all?
Does it crank and doesn't fire?
Does it crank, fire then die?
Does it crank, fire, idle, and then when you start driving, it dies?
Is it cranky?
Is it cranky?
