Startup Trembling 1.8 T
It's trembling when starts after a humid night, or rain. It trembles both at idle and acceleration. It does that for 5 minutes, then, after a short heat, it works normal.
The MIL light blinks for couple of minutes and remaines ON.
I checked the spark plugs and the and they seem to look fine. I checked the conectors to the coils and the amplifier and they were dry.
I've seen a coil was changed and I heard (previous owner) the amplifier was changed as well. How can I check this?
You really need to get the VAG codes. After that if it says one cyclinder is misfiring or multiple misfires, play musical coil packs.
If its cylinder 2 then its most likely your ICM. Mine went out a few months ago. I used this <a href="https://forums.audiworld.com/a4/msgs/1594531.phtml" target="_new">write up</a> to test mine. I tested volts instead of OHMs and was able to see that the right amount of volts were not getting through to the cylinder 2. Search, there is a lot out there. If it is your ICM buy a Huco aftermarket for like $150 instead of paying $400 for a bosch one that will probably break down the line again.
Ken
Ken
SolidFish
08-30-2007 07:29 AM
maaliish
09-05-2006 02:18 PM
JohnelP
11-24-2005 07:41 AM
