Steering Groan noise low pulling in or out of parking spaces
AudiWorld Uber User
Anyone resolve this?
I spent 30 minutes on search and came up with:
1) check the fuild - done
2) tie rod ends
3) balljoint in teh front suspension
4) power steering pump and or rack
What have yo done to fix this?
TIA
-Michael
2) tie rod ends
TIA
-Michael
speed, just don't hold at stops more than 3 seconds to reduce wear on PS pump. This can help to fluid any air in PS system. Recheck fluid after lowering car.
Definetly one of those things
But need more info...more than likely power steering if its when your turing the wheel
If not then, well obviously control arms or tie rods hands down
There was a post earlier about how to change the PS fluid an an A8 that would work on our cars, but it doesn't seem to get it all changed out from the rack, because I had the stealer do it on the cheap and I think they did it that way. It lessened but didn't totally fix the problem. There's a way that requires you to jackstand the car, disconnect the return on the rack (not easy), turn the wheel side to side with the car on so the power steering works, and dump fluid into the system as fast as it drains out.
I think more details are somewhere in the archives. Yeah, that helped, didn't it.
~DonQPremiumTequila~
09-14-2018 02:46 PM
TEB
06-24-2008 02:43 AM
nemesisa6
10
10-21-2007 08:49 PM
Thomas D
06-04-2006 05:05 PM
