Steering Wheel Column rattle
Guest
Posts: n/a
The steering column can make a few kinds of noise. The plastic shrouds can rattle together. The plastic shrouds can contact the steering wheel and make a rubbing plastic noise. The adjustment device (friction plates) in the steering column could be loose- but highly unlikely if the column is not moving freely up and down. Try moving the position of the column a little bit and then relock it and drive it for a while. The "clockspring" is also one of the usual suspects. It is the electrical connection for the airbag and other electrical devices in the steering wheel. Essentially it is a flat wire and plastic ribbon wound on itself. The slop in the winding allows the steering wheel to turn from lock to lock while maintaining a direct electrical connection (important for airbag circuitry). The slop, however, can allow the ribbon to slap against itself during rough roads. The other possible noise would be steering driveline slop. This noise would not exist when light torque is applied to the steering wheel.
I personally have not had any noises, and I am sensitive to it.
Good Luck
Mark 99.5 1.8tqms
Good Luck
Mark 99.5 1.8tqms
Guest
Posts: n/a
It is easy to pull off, just grip the top edge and tug. There are hooks holding the bottom edge, so don't pull it straight out or you could break the hooks. You might just try pulling it off to see if the sound goes away. I had a couple of shiny spots on mine where it was rubbing, I put some Chapstick on it (OK, that is what I had sitting there at the light) and it went away.
Guest
Posts: n/a
but nobody seems to know what I'm talking about. I describle mine as more of a "clicking" sound that mainly happens when I turn the steering wheel in either direction. Sometimes very noticeable, others not. I'm sure it's coming from the steering column.
BDW
Looks like I'm experiencing some rattling from steering wheel. It sounds like a wire touching the casing from inside, making a vibration noise. when the wheel in upside down position (turning) there is no noise.
tried repositioning the steering wheel column up and down, and back and forth with no difference.
is this the same we're talking about here? Any remedies? Driving me crazy.
shejjang
09-23-2008 06:14 AM
mm
11-05-2001 01:39 PM
