stereo help....
i really dont know much about car stereos.
my question is if i'm runnin 2 12" subs that are 600 watts rms wit dual 2 ohm v.c. would an amp rated at rms power 2 ohm 1500x1 run the subs?
my other question is the front door speakers are 4" and the rear doors are 6 1/2" right? what's the speaker size that are on the rear deck?
one of my rear speaker on the rear deck is blown. should i replace them when i replace my door speakers when i add my subs? i know i need a new hu when i replace my door speakers. the speakers on the rear deck dont have any vocals coming outta them. are they mini subs?
U have 2 Dual Voice Coil Subs right?? Both 2 Ohm??
U have a 1x1500 @ 2omh Amp??
If u run both subs of that amp, u will be running the amp at 1ohm. Make sure it is 1 ohm stable. I would suggest running the subs in Stereo (if the amp is a 2 channel, not a monoblock - which u didn't state) therefore running the amp at 2ohm. If the amp IS 1 ohm stable. Do it!!!
Otherwise u could run them in Series. 2 + 2 Ohm subs will run the amp at 4 ohm.
Can't help u with speakers, pretty sure rear deck is 6.5" though.
Hope this helps some.
the subs are rated at 600 watts rms wit dual v.c. @ 2ohm each. i dont have the amp yet, i'm just checkin to see the amp (memphis 16-mc1500d) would run the subs. what power rating should i look for to run these subs?
CTA4AVANT
02-10-2005 12:28 AM
quattro25
03-15-2004 12:34 AM
SurfinSilly
10-01-2001 05:18 PM
