Still getting the 17549 - Load Calculation Cross Check: Implausible Value P1141 - 35-10 - - - Interm
#11
But you can easily plug a vac gauge to the FPR to do a quick check anyway.
How about grab a meter to check wiring from MAF to ECU? Could be loose or bad wiring.
Any comments from the OBD forum?
#12
Head Cat Herder
![](https://www.audiworld.com/forums/images/ranks/admin.jpg)
![](https://www.audiworld.com/forums/images/ranks/editor.jpg)
it reads perfectly, though one might suspect that a faulty connection would do that, eh?
#13
to it's final destination. On the TT's, the most susceptible wiring is the one to the ignition coils. The heat surrounding the area makes the insulation brittle resulting in exposed wiring. The wire connectors (moisture and contamination) are another suspect.
Hope you find it though. I hate intermittent problems - took me months to find out my N75 on the TT was failing only with elevated temps. I had to dunk the thing in hot water to confirm my theories.
Kris Hansen
VAG-COM Discussion
07-02-2008 11:50 AM
TTGram
10-04-2005 03:43 PM
bretto
03-13-2003 05:23 AM
