Still no heat...hate to bother..
OK, so I love this forum. I have a 1997 A4 Quattro with the V-6. I really enjoy the car, having bought it over the summer. Now it is starting to get cold here over night, and the car has no heat. If you leave the system off for a while, then cut it on, it blows warm for about five seconds, then goes luke warm. I have replaced the thermostat, the water pump, bled the system, flushed the heater core( both hoses are hot), new coolant temp sensor, new expansion tank and a few new hoses. I have read through numerous posts and can not seem to figure out what to do after having done all that I have done. i assume that it is some sort of flap, or vent or something that is not opening...but what, where, how...please help. Thanks.
I have a similar problem. Check the link out; the guy fixed it @ post 51.
http://www.advrider.com/forums/showthread.php?t=411979
It seems the Audi shop was content pushing cold water from a garden hose to get things blown out and this is also something I paid dearly not once but 2 times.
So after I refilled with coolant, guess what, no heat. Must not have got all the air out, so I follow the bleed instructions (little bleed hole in upper core hose) and get more air but now heat quits at idle so I bleed some more but no more air. I decide to unfasten expansion chamber and raise it while revving the engine and hear glug, glug, glug. Now I got burn your hand heat!"
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!![Cool](https://www.audiworld.com/forums/images/smilies/cool.gif)
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
![](https://www.audiworld.com/forums/signaturepics/sigpic191288_1.gif)
BTW, can anyone help me with a couple of codes?
1. 16500 Coolant temperature sensor-G62 Not a plausible Signal P0116
2. 16688 Cylinder 4 misfire detected P0304
It seems number 1 is a relatively easy fix for the mechanically inclined. I'm going to try that as well. But wonder what to do for the stock radio code. Stealership?
Any input appreciated. Didn't want to start a new thread when the symptoms I have are very similar; no hear-lots of air and terrible gas mileage.
Error 2 is usually a bad coil pack, assuming you have a 1.8t.
Here is what you need:
New Coolant Temp Sensor - In stock and easy to reaplce
![](http://www.ecstuning.com/product_library/3862/300/Coolant%20Temperature%20Sensor%20With%20O-Ring.jpg)
New Coil Pack - In stock and easy to replace
![](http://www.ecstuning.com/product_library/19843/300/Coil%20Pack%20-%20Priced%20Each.jpg)
BTW, it's a 96/2.8. Does that change the instructions for coil pack change?
Appreciate the input.
