Stock air filter vs. aftermarket performance air filter question.
Guest
Posts: n/a
OK, the reason the aftermarket air filters provide more performance is b/c they are less restrictive, right? Well, that means they are less of an air filter, right? If that's the case, do they allow small particles to pass through the filter and into your engine? Is the small extra hp worthwhile? Perhaps changing the stock air filter(w/another stock one) more frequently would be a decent alternative? Just wondering. Any comments would be appreciated.<p>JT 99' 1.8Tqms
Guest
Posts: n/a
Re: Stock air filter vs. aftermarket performance air filter question.
I disagree...They most likely do not provide the power increase they claim. However, ever since I put in a K&N into my car, the engine runs much smoother. I think it was well worth the few bucks.<p>Marcin R.<br>---<br>'98.5 A4 1.8Tqms
Guest
Posts: n/a
Re: Power is not the main reason to get a better filter...
Check the archives, several people have posted independent test of the filtration and flow characteristicts of K+N (gauze) and Ram Air(foam) as opposed to paper(stock), and the rest. What the test show is paper is the worst. You may get some HP gain but the main reason to switch is better air flow, better filtering, longer life. In a Turbo the more air you can flow the longer the boost stays up, so HP gains may not go up, but performance will and the car will be more efficiant. My guess is about 5 hp gain, but more important is the way the motor will run and torque gains. If you open up the exaust like a 70m cat back exaust, then a better flowing air filter will become even more usefull.
Guest
Posts: n/a
Is it difficult to put in aftermarket filter and which are the best?
I want to know how difficult it is to add an aftermarket filter to my 2.8 A4.<p>What is the performance gain on these things?<p>Which are the best?<p>Which offer the most performance and air filtration?<p>Where can i buy them?<p>Thanks.
Guest
Posts: n/a
I disagree also
Coupled with an exhaust change the K&N, RamAir, or Jamex filters can be felt. It is one of those "1+1=3" things. The sum of the whole is more than the sum of the parts.<p>Steve S.<br>97 2.8QM<p>P.S. Some cars get better gains from K&N filters than others....I say spent the $39 +tax<br>at Imparts.com
Guest
Posts: n/a
better performance YES, but more power no (more)
I put a K&N filter in my 98.5 2.8 and I think the acceleration is better. However, without actual test it could be my wishful thinking. The one thing I did notice is better performance in the 3500-4000 rpm range. The 30V has a plateau in the power in this area. After putting in the K&N I noticed better perfromance in this zone--its not as slugish--and the car sounds better also. I say its is worth the $39.<p>Paul
OC SoCal Agent Farva
13
06-08-2004 10:59 PM
Griff
14
01-18-2001 06:21 PM
