stock vaccum at idle/stock boost
I just added a boost gauge and i was wondering what was normal.
i see about 12-13 inches at idle, and at max boost i see about 7psi, maybe 7.5
stock except for a k&n filter.
thanks
thanks
esp the vac. i see 23-24 in/hg at idle, but im hgher than most it seems, normal ive seen is 17-20. and when i was stock id see a 10-11 psi spike and it would settle in at 7-8.
oh and what year are you? if you are '01 or '01.5 i belive stock boost is higher (170 hp engine) its a 12-13 psi spike with a 10-11 psi hold IIRC.
sounds like you might have a small boost leak?
I see about 25-30Hg/in at idle. And stock boost should be between 8-12 at WOT. I cna't remeber the exact numbers but those are off so I'm saying you have a leak. Time to trace your lines!
you cant do ... then not put anything in the message field!!!!
or did that just mean to read your above post? lol
you get 25-30 in/hg at idle? i thought mine was high at 24.
or increased your CR to about 10:1 or higher. Stock vac should be around 20 and during coasting in gear it should be 25. But #'s will change with elevations.
im right at sea level.
my gauge might be off by 1/2 of a "mark" though
so 22.5-23.5, that seems ok, yes?
I did a compression test and i get 180-190 psi across the board.
