Suspension Question... Difference between Quattro and Frontrak... suspension..
Quattro has independent rear suspension while Front Trak does not. Therefore better handling with Quattro.
check out this URL
http://www.bath.ac.uk/~en8jd/rearsusp.htm
FrontTrak has the "Twist Axle" as the Brits call it.
Quattro has the "Trailing Arm" Independent Rear Suspension.
There are different part no's for Eibach ProKit springs for the FrontTrak and the Quattro.
The Quattro is heavier, and has a different wheelbase...Heavier and different load distribution would call for different spring constants (= different springs)
Since the rear setup is completely different, I would imagine that the rear springs can not be the same. I could be wrong.
Call or e-mail Eibach, I have the Pro-Kit in mine and I had to wait over 3 months for mine to come in. I double and triple checked them before getting the install done...
From a manufacturing standpoint (since I'm a product design engineer), less independent parts the better. There is a reason for separate part no's... especially if the cost is the same for both. They would just build and stock one model for both FT and Quattro if they could. It might be swapable, but the springs might not perform to spec in the "wrong" vehicle. (i.e., mismatched damping of shocks and springs)
Hope you find a solution!
I hope in the future somebody has time to deteremine which parts are switchable and which are not. I mean VW and Audi are about, but VW parts aren't as well expensive as Audi. Well its not that much less expensive but still. What if you find this really cheap exhaust but its made for the 4 motion passat.. is it goign to fit the audi's? or how bout the gauge cluster from a s4 into a older a4. ?? you know how it goes.
WPGQuattro
05-11-2005 03:03 PM
S6 4RiNGS
Audi Original "S" Cars
01-04-2004 07:10 AM
bugbbq
08-27-2001 11:38 AM
