sway bar question for FWD a4
Im going to put on a 28mm neuspeed sway bar..here is the thing i have quite a bit of extra weight in the trunk from stereo equipment, dont know the exact weight but its from 150-300 lbs extra...should i set the sway bar to be stiffer to compensate for the extra weight or softer to compensate for the extra weight?
I want my sway back, bitch! got a workout equipment idea :P But anyways, if you want more over/under --steer you can always easily adjust... Personally, with all that weight you got back there, I'm not sure I would want it on stiffest, especially with fwd. Sliding the back end out with all that rear weight, hmmm, unless you're already used to that type of driving....
Did you go straight to Neuspeed for the parts? That's still a sweet deal if you think about it. Rear sway is gonna be so much fun when you get it. The c/os? I ordered them from Eric/Spp a while ago. They've been on my car for a couple of days. You'll see my car on Thursday anyway...
