Tail Light Issues...
Well after just getting my 97 A4 back from the shop costing 1500 dollars I realized the right tailight bulb (the one right above the back up light) was out. Simple fix I thought. Replaced the bulb and it still isn't working. Turns out the old bulb is good as the fillament is still intact and when tested it works fine. So it appears to be the socket and or wiring. Is this a common problem and is there an easy fix. I couldnt figure out which wires went to the socket to test for power so if anyone knows which those are that would help alot.
Thanks!
Thanks!
it is fuse #22 on my car.
do you have the original tails or did you upgrade to a newer style and rewire it? Either way, I would first check the fuses. If the fuse is fine..report back and we will hunt down the cause of this problem.
J
J
hoTTub
9
11-05-2006 04:54 AM
