Tail lights dashlights stopped working
Hi all.
My dashboardcluster light suddenly went dark. Everything still works in it, besides the green symbol that shows you the lights are on.
dimmer works normally with the clock temperature etc too.
With this the taillights and front citylights/runninglights also went out.
Those last are all on fuse 22 and 23. measure no power at all on the 2 fuses.
brake/fog/index/front normal/highbeam lights all work.
is this a light switch issue? Or something else known?
what to do?
what to do?
Noone?
i read a lot about the switch making the front lights not work. But not with the rear lights.
is there an easy way to test the switch? Can i take the cable apart somewhere under the dash and connect the pins to see if the lights work then?
or do i need to take the steering wheel of for that?
parsko
01-26-2009 08:54 AM
cr8n
01-23-2002 11:49 AM
