Tap for Boost Gauge
AudiWorld Expert
I am reading over the boost gauge directions, and they specify 2 different locations to tap for boost.
1. on the back of the engine block, it reccomends using this for pre 99.5 A4
2. in the front of the engine block. For 2000 and later A4
I haven't opened up the hood yet to take a look, but wanted to see some opinons on the reason for this...Anyone with a 2000 done this? And where did you tap?
Thanks<p><A href="http://registry.audiworld.com/audi/registry/details.asp?car=4586">
<img SRC="http://members.bellatlantic.net/~theos2/signature.jpg"BORDER=0></a>
I will know for certain tomorrow when I get mine installed by cmh<p>- <a href="mailto:adhand@san.rr.com">Anand Dhanda</a>
'00 A4 1.8TQMSx Silver/Onyx
Wett 1 Bar, F/R Fog Mod, Clear Corners,
S4 Grille, Jamex Air Filter, LLTek Shift ****,
Euro Plate "2PE C ME", Westach Boost Gauge
AudiWorld Expert
The front line goes to the bypass valve. If this leaks, you'll get low/no boost which is exactly what your gauge is going to help you recognize. The line at the rear goes to the fuel pressure regulator. If you tap this and it leaks, you'll run lean which is very bad.
Good luck,
Rich
Good luck,
Rich
<p>Regards,
Rodney
'99 A4 1.8tqms<ul><li><a href="http://www.seansa4page.com/mya4s/97/boost/boost.html">Sean G.'s Boost Guage installation</a></li></ul>
Rodney
marcel
09-04-2000 12:03 PM
Carol from Canada
08-19-2000 01:45 PM
Anand@4Induktion.com
08-17-2000 10:44 PM
